Vector 2 and Vector 2S Status LED Lights
The Vector 2 and Vector 2S system features status LEDs on each pedal pod. Below is a table that will give you the meaning and troubleshooting tip for each status LED.
LED Light StatusPedal Pod StatusTroubleshooting Tips
1 green flash every 10 secondsThe Vector System is working properlyNone
1 red flash every 10 secondsThe Pedal Pod battery is lowChange batteries
2 green flashes 10 secondsThe pedal pod is reporting that it is not connected to the pedalCheck the pod contacts for damage, or corrosion.  Check the spindle connection for dirt, debris, or corrosion
3 green flashes 10 secondsThe pod is connected to the pedal, but cannot communicate with the Garmin device it is paired to.Check connection between Vector and previously paired head unit.  If necessary, repair pedals with heat unit
4 green flashes 10 secondsThe pedal pod is searching for the other pod (Should only occur for left/right power systems)Check installation of opposite pod, ensure connection is clean and it is connected.  Confirm battery in opposite pod is good.
5 green flashes 10 secondsThe installation angle is not set or cannot be detectedIf paired to an Edge head unit, you can go through the set install angles steps from the Vector sensor menu options.  You can also reset install angles by removing batteries from pedal pods for 30 seconds.  Once batteries are reinstalled, the head unit should prompt you to set install angles again
6 green flashes 10 secondsThere is a hardware installation errorVector 2 has detected the use of a 1st generation pedal pod (sliver pod).  Remove silver pod and install the correct Vector 2 pedal pod (black pod)
7 green flashes 10 secondsThere is a software update in progressAllow update to finish installing
