Automatic Hole Transition on Garmin Approach S10 Watch
All Garmin golf capable watches will automatically transition to the upcoming hole when brought near the hole's far back tee box.
If for any reason the device does not automatically transition, transitioning can be done manually.
Manually Transition Holes on Approach S10:
  1. With a round started, press OK
  2. Select Change Hole
  3. Press Up or Down to highlight desired hole
  4. Press OK
Doing this may be necessary if the device does not transition automatically or if it jumps to the next hole earlier than desired.
