Data Limitations of the Montana 700 Series
When sending or creating files for a Montana® 700, 700i, 710, 710i, 750i, or 760i outdoor handheld, keep in mind the following limitations:
  • 2,000 GPX files
  • 10,000 waypoints
  • No limit on geocaches (outside of max number of GPX  files supported and memory available)
  • 250 routes, 250 points per route; 50 points turn-by-turn routing
  • 250 saved tracks
  • 300 saved FIT activities
  • 2,000 archive tracks1
  • 20,000 points per track
  • 500 custom map tiles
  • 250 JNX files (satellite imagery)
    • Limit is combined total of BirdsEye imagery files downloaded using BaseCamp™ software and Satellite Imagery files downloaded using Map Manager on the handheld. Up to 100 of those Satellite Imagery files can be downloaded using Map Manager on the handheld.
  • 15,000 Mapping segments2
Each GPX file can contain a mixture of waypoints, geocaches, routes and tracks. If the GPX file containing a waypoint or geocache is deleted, the waypoint will no longer be available on the device.
When utilizing routes, only 50 points can be used for turn-by-turn navigation on roads or trails.
1 Archive tracks do not count against the GPX file limit; 1 archive track per GPX file.
2 See Related for more information on map segments.
Related
