Checking Time of Day and Battery Level on the Approach G12 or S12
The main screen during a round on the Approach® G12 or S12 golf device is the hole view which shows the front, middle, and back distances to the green. At any time, you can check the time of day and battery level during the round.
Going to the Clock Screen During a Round
- From the hole view, press Back.
NOTE: The battery gauge appears above the time. - Press Back return to the hole view.
The device will remain on the hole view to continue playing the round.
Going to the Clock Screen Not in a Round
When you power on your device, it will open to the menu with Play Golf ready to be selected. The device will take about 2 minutes to time out and go to the clock screen which displays the time of day and battery level. You can go to the clock screen before the timeout.
- From the menu, press Back.
NOTE: The device will remain on the clock screen. - To enter the menu, press OK.
- If you wish to start a round, select Play Golf.
