- From the Main Menu Select
- Select Reset All Settings
- Select Yes
The sight will then reset back to factory defaults. The initial calibration can be started again.
Resetting the Xero® A1, Xero® A1i, or Xero® A1i Pro bow sight back to factory default settings will remove all profiles and calibration settings and return the bow sight back to its initial setup out of the box.
