Pairing a Replacement inReach Device With Your Phone
If you received a replacement inReach® satellite communicator from Garmin, or upgraded to a new device, you will need to take some steps to transfer your inReach service and get the replacement device connected to your phone. It is important to follow these steps in order to ensure that you remove the old device properly, and add the replacement device properly.
1. Confirm App Compatibility if You Have Upgraded to a Different Model of inReach Satellite Communicator
If you have upgraded to a different model of inReach satellite communicator, it may need to be used with a different app.
App Compatibility List
Earthmate® App
  • inReach Explorer®
  • inReach Explorer®+
  • inReach® Mini
  • inReach SE®
  • inReach SE®+
Garmin Explore™ App
  • Alpha® 200i
  • Alpha® 300i
  • GPSMAP® 66i | GPSMAP® 67i | GPSMAP® 86i | GPSMAP® 86sci
  • inReach® Messenger Plus
  • inReach® Mini 2
  • Montana® 700i | Montana® 710i |Montana® 750i | Montana® 760i
Garmin Messenger™ App
  • Alpha® 200i
  • Alpha® 300i
  • inReach® Mini 2
  • Montana® 700i | Montana® 750i
2. Remove the Old inReach Device From the Associated App
Refer to the instructions for the app(s) being used with your inReach satellite communicator:
3. Forget the Old inReach Device From the Bluetooth Menu of the Phone
Refer to the instructions for the phone being used with your inReach satellite communicator:
Unpairing from an Android Device
  1. Open Settings on your Android device.
  2. Select Bluetooth or Connected Devices.
  3. Select the inReach Device or select Settings Icon.
  4. Select Unpair.
Unpairing from an iOS Device
  1. Open Settings on your iOS device.
  2. Select Bluetooth.
  3. Select the Lowercase i next to the inReach device.
  4. Select Forget this Device.
4. Pair the New inReach Device With Your Smartphone and Transfer Your inReach Service
For instructions on pairing your inReach device and transferring service, see - Transferring Existing inReach Service to Another inReach Device.
Related
