Flat Mount Kit for GPSMAP 74xx and 76xx Series Chartplotters
While the GPSMAP 74xx / 76xx series has many things in common with the GPSMAP 8xxx series, they do not share Garmin-made flat-mount kits. Garmin will not be selling flat-mount kits for the GPSMAP 74xx / 76xx series.
If you choose to install the GPSMAP 74xx / 76xx devices in a flat-mount anyway, keep in mind that Garmin will not be able to assist you. You are flat mounting the device at your own risk.
