VIRB / VIRB Elite Action Camera powering down randomly
The VIRB REC slider uses a magnet switch to start or stop recording. When the switch is slid into the recording position, the device will power on. If the VIRB seems to be turning on at random, a nearby magnet field may be to blame. Check your environment for external magnetic fields that may be activating the VIRB.
Common items that can have magnets could include:
  • Equipment: camera, cases, a purse
  • Apparel: jacket, magnetic buttons
  • Environment: cabinets, car parts
The strength of the magnetic field will determine the distance you will want to keep the VIRB from other equipment to prevent it from turning on by itself. Being mindful of your environment will help prevent this issue.
