InReach Tracking on the Alpha 200i
inReach® tracking on the Alpha® 200i dog tracking handheld is a great new feature where people at home can see you tracking on a special dedicated website. Your friends can view your location on a computer web browser or even a smart phone internet browser.
An active inReach subscription is required.
inReach tracking works by uploading of your position coordinates periodically to the Iridium satellite network.
The information is then sent to a Garmin provided website.
Each account has its own dedicated website address URL to share with friends.
Either a LiveTrack™ page or MapShare™ page is used for this, depending on which you choose to enable on your account.
You can share your dedicated website URL address with your friends via an inReach message (email or SMS text).
It can also be sent from within your account at explore.garmin.com.
By default, inReach tracking is set for uploading a tracking point every 10 minutes.
See Related below for information on setting up your dedicated tracking website.
Starting inReach Tracking on the Alpha 200i Handheld
You must manually "Start Tracking" on the Alpha 200i handheld to activate this feature each time you want to use it.
Navigate to the Main Menu on the Alpha 200i handheld.
Select inReach.
Select Tracking.
Select either:
Start Tracking to begin inReach tracking and start your activity.
OR
Send MapShare1 to send a link to your tracking page to recipients as you start your inReach tracking. Either a LiveTrack link or a MapShare link will be sent, depending on which you choose to enable on your account.
Select Type Recipients to manually enter contact information or select from a list of saved contacts.
Select Send Message when done.
1 Send MapShare will count as a text message for inReach subscription plans that have limited message options.
