Using the Alpha 100 with the Alpha TT25 or Alpha T20 Collars
The Alpha® 100 dog tracking handheld is compatible with the Alpha TT25 and Alpha T20 dog tracking collars. There are, however, limitations to use with the Alpha 100 handheld.
Changing Update Rate
To change the update rate you will need to do the following:
  1. Pair the TT25 or T20 dog collar to the Alpha 100 handheld.
  2. With the collar selected on the Alpha 100, select the menu icon at the bottom of the screen.
  3. Select Change Update Rate.
null
Changing Beacon Color Lights
You are unable to change the beacon color lights on the Alpha TT25 and Alpha T20 collars from the Alpha 100.
