Troubleshooting Wireless Updates on an Automotive GPS Navigator
See the Wi-Fi troubleshooting below if you are unable to successfully complete a wireless map or software update with your home Wi-Fi network. You may receive the messages "Unable to connect to the update server" or "Failed to associate with the network, ensure the device is in range or confirm mac address is not blocked.
You may see an exclamation point (!) on the Wi-Fi symbol on your device if it's not connected to a Wi-Fi network. The exclamation point will show anytime the device has a Saved Network it detects, but cannot connect to or has not yet connected to.  It may also show if it cannot detect an internet connection from the Wi-Fi network or if a "No Data Connection" message is received.
NOTE: See Reinstall or Change Map on an Automotive Device if your map is missing and/or your device does not give the option to update the maps after a failed map update via Wi-Fi.
  • Reinstalling the maps is not available via Wi-Fi and must be done by plugging the device into a computer and using the Garmin Express™ software.
NOTE: Garmin Wi-Fi devices are not compatible with Captive Portal networks. These are often found in public areas. See Using a Wi-Fi Device on a Captive Portal.
See Map or Software Update Issues when using a Mobile Hotspot, Tethering, or Slow Internet Connection if the update was started using a slow internet connection.
See the Appropriate Garmin Video Tutorial for Steps to Complete a Wi-Fi Update
Camper 795 caravan and Motorhome Sat Nav or RV 795 RV Navigator
CamperCam 795 Motorhome Sat Nav With Built-In Dash Cam or RVcam 795 RV Navigator With Built-In Dash Cam
dēzl™ LGV610, dēzl™ OTR610, dēzl™ LGV710, and dēzl™ OTR710 GPS Navigators
dēzl™ LGV620, dēzl™ OTR620, dēzl™ LGV720, and dēzl™ OTR720 GPS Navigators
dēzl™ LGV820, dēzl™ OTR820, dēzl™ LGV1020, and dēzl™ OTR1020 GPS Navigators
dēzlCam™ LGV710 and dēzlCam™ OTR710 GPS Navigators With Camera
dēzlCam™ LGV725 and dēzlCam™ OTR725 GPS Navigators With Camera
Garmin Drive™ 53 & Live Traffic GPS Navigator
Garmin DriveSmart™ 66, Garmin DriveSmart™ 76, and Garmin DriveSmart™ 86 GPS Navigators
Tread® and Tread® - Base Edition GPS Navigators
Tread® 2 GPS Navigator
Tread® 2 - Overland Edition GPS Navigator
Tread® 2 - SxS Edition GPS Navigator
zūmo® XT GPS Navigator
zūmo® XT2 GPS Navigator
All Other Devices
Minimum Password Requirements
Wi-Fi Specifications
Below are the Wi-Fi-related specifications for Garmin automotive devices with Wi-Fi capability.  A Virtual Private Network (VPN) can be used as long as it meets the following requirements.
Supported Frequency: 2.4 GHz only.
  • The following devices work on a 5 GHz frequency: dēzlCam OTR710, dēzlCam OTR725,  dēzl OTR500, dēzl OTR610, dēzl OTR620, dēzl OTR700, dēzl OTR710, dēzl OTR720, dēzl OTR820, dēzl OTR1020, Garmin DriveCam™ 76, Garmin DriveSmart™ 55, Garmin DriveSmart™ 65 series, Garmin DriveSmart™ 65 with Amazon Alexa, Garmin DriveSmart™ 66, Garmin DriveSmart™ 76, Garmin DriveSmart™ 86, RV 780, RV 795, RVcam 795, Tread®, Tread® 2, Tread® 2 - Overland Edition, Tread® 2 - SxS Edition, zūmo® XT, and zūmo® XT2 GPS navigators.
Security: Unencrypted, WEP, WPA, and WPA2.
NOTE: Hidden networks are not compatible with Wi-Fi updates on some Garmin devices.
Acquire a Satellite Signal for Accurate Time
The time displayed on your device must be accurate to properly communicate with our update services. This time is automatically set when you receive a satellite signal.
A satellite signal is required before attempting a Wi-Fi update if the device has just been turned on for the first time and hasn't been used for navigation.
  • Take the device outside in clear view of the sky until it obtains a signal.
    • Signal bars in the upper left corner of the Where To? and View Map screen show satellite signal strength.
    • Or, the location icon will appear in the top bar on some devices.
A satellite signal should not be necessary for later updates if the time is displayed accurately on the device. Obtain a signal again if the time on the device becomes inaccurate.
Visit the Support Center if your device is unable to acquire a satellite signal.
  • Enter the product  name or the serial number of your device.
  • Once your device is selected click Other and search for "Satellite Acquisition".
High-Speed Internet Connection
See the Detailed Video Below to Learn About Wi-Fi Connections for Updates.
A wireless connection to home high-speed internet (e.g. fiber, cable, DSL, etc.) is required to successfully complete a Wi-Fi update.
  • Connections with data caps or restrictions should not be used due to the size of a map update.
  • Slower connections (e.g. satellite, fixed wireless, dial-up, etc.) and mobile broadband (e.g. MiFi, AirCard, cell phone tethering, etc.) should not be used.
Internet connections requiring a login, like some public Wi-Fi connections, cannot be used. These public Wi-Fi networks are often called “captive portals.” See Using a Wi-Fi Device on a Captive Portal.
External Power
External power is required to perform a Wi-Fi update. See External Power Options for Wireless Updates.
Remove and Reconnect to the Wi-Fi network
To Forget the Wi-Fi Network:
  1. Touch Settings or the gear from the main menu
  2. Touch Wireless Networks or Wi-Fi
  3. Scroll down and touch Saved Networks
    • (skip this step on some devices)
  4. Touch the listed network
  5. Touch   or FORGET to delete the network connection from the device
  6. Touch Yes to confirm if prompted
To Add a Wi-Fi Network:
  3. Touch Search for Networks
  4. Touch the preferred network
  5. Enter the password to the Wi-Fi network if prompted
  6. Touch Done if prompted
Attempt the update again after reconnecting to the network.
Reset the Wi-Fi Router
There may be a problem with your internet connection if the update is stopped, slow, or disconnecting. A common troubleshooting tool is to reset your Wi-Fi router. This can generally be done by unplugging the router for 30 seconds and then reconnecting.
Contact your Internet Service Provider (ISP) for additional troubleshooting if your wireless router continues to have network connectivity issues.
Restore the Wi-Fi or Reset the Wi-Fi Network Settings
    • On some devices,
      1. Swipe the page up
      2. Touch Personal
      3. Touch Device Reset under Personal
      4. Touch Network settings reset, or Reset Wi-Fi, mobile & Bluetooth
      5. Touch Reset Settings
      6. Touch Reset Settings again, then skip to #6
        • This will reset all network settings, including Wi-Fi, Cellular data, Bluetooth
  3. Touch the menu button (three horizontal lines)
  4. Touch Restore Wi-Fi or Restore
    • Skip this step on some devices.
  5. Touch Yes
  6. Attempt the update again after reconnecting to the network.
Updates must be done using a computer if the above steps do not resolve the issue. Go to the Support Center and enter the product name or the serial number of your device. Once your device is selected, click in the search box and search for “Updating Automotive Maps and Software with Garmin Express".
Related
