I am Unable to Operate the G1000 NXi Simulator on my Computer
The G1000® NXi simulator is a program that is graphic memory intensive in nature. It must be the only application running on your PC. In some cases, even though your computer meets the minimum requirements, the simulator may not function properly. This is due to the unique configuration of each computer and the extra processes and procedures that are utilized by that computer. When you run the simulator, make sure you have everything else (other programs) closed. Sometimes it helps to close programs running in the background (PDA, Networks, etc.).
G1000 NXi Simulator Computer Requirements:
  • Windows® 10 (Mac® operating systems are not supported).
  • 8 GB RAM.
  • 3.5 GB free hard disk space (4.5 GB free hard disk space required with FliteCharts® option).
  • USB port.
  • Microsoft DirectX® 9.0c (included on the trainer USB drive).
  • Video Card/GPU: DirectX-capable card with a minimum of 1 GHz @ 8GB DDR3 memory.
  • Screen resolution: 1920 pixels wide x 1080 pixels high.
  • Sound card (optional).
If you are still having issues with the simulator, uninstall the G1000 NXi simulator and make sure that you install it again in the correct folder. Move the installation path to the C: Drive and to the User Folder.
Related
