Pairing a Bluetooth Phone with a Camper/RV device
You can use your Camper/RV device with your cell phone by pairing them. This allows you to make and receive phone calls through your Garmin device.
A Detailed Video Walkthrough of the Pairing Process can be Found Below.
iPhone:
Android:
Before you begin, set your phone to "Find Me" or "Discoverable" mode. If you are not sure how to do this, refer to the owner's manual or documentation that came with the cell phone.
To Enable Bluetooth on your Device:
    1. Touch Settings
    2. Touch Bluetooth or Wireless Networks
    3. If no checkmark is present, check the box next to Bluetooth
Your device will now be ready to pair with a phone.
To Pair and Connect the Phone with the Device:
    1. Touch Settings
    3. Touch Search for Devices
    4. Touch OK on the message that prompts you to set your phone to Find Me or Discoverable mode
    5. Touch the name of the desired phone from the list of compatible Bluetooth devices in the area
    6. Touch OK
    7. Enter the passkey displayed, if prompted
A message should display that the Garmin device successfully paired with the phone. When the device and phone are within range of each other and both have Bluetooth enabled, they will automatically connect.
