Shaping Points Alert on Device when set to "Don't Alert on Arrival"
Shaping points set to "Don't Alert on Arrival" in BaseCamp™ software are not supported by outdoor handheld devices.
This means that if a route is created in BaseCamp software including non-alerting shaping points, the handheld device will treat those points as route points and will be alerted on the device accordingly.
Select an option below for an example.
Visual Example: Route Created in BaseCamp With Shaping Points Set to "Don't Alert on Arrival"
Visual Example: Same Route Displayed on a Garmin Outdoor Handheld With Shaping Points That Will AlertShaping Points Alert on Garmin Outdoor Handheld Device
