You are viewing an article that is not available in your currently selected language. You can choose another one below.
Transfer user data from MapSource to a GPSMAP 6xxx or 70/72xx series chartplotter
MapSource is a program used to manage user data such as Waypoints, Tracks, and Routes and send data to compatible devices.
A SD card is required to transfer the information from MapSource to the GPSMAP 6xxx or 70/72xx series device. The SD card will need to be prepared before it can be used. To prepare the SD card, please follow these instructions:
  1. Insert the SD card into the device while the device is OFF
  2. Power ON the device
  3. When the Warning Screen appears, the card is prepared and can be removed from the device
Once the SD card is prepared, please follow these instructions to transfer the user data to it:
  1. Open the MapSource program
    1. Create the new user data, or open a saved file with the user data
  2. Ensure all of the user data needed is listed in the correct tabs (i.e. Waypoints, Routes, and Tracks) that appear on the left side of the MapSource program
  3. Insert the SD card into the computer
  4. Click Transfer at the top of the screen
  5. Choose Send to Device
  6. When the new box appears, make sure the Device box says the model number of the device being used (i.e. GPSMAP 7215)
    1. If the device is not listed, please click on the drop down box and choose the correct device
  7. In the section titled What To Send, un-check the option for Maps
  8. Make sure the other options like Waypoints, Routes, and Tracks are checked, if applicable
  9. Click the Send button
  10. Click the OK button when the message The data was successfully sent appears
At this point, the data has been transferred to the SD card. To copy the data from the SD card to the device, please follow these instructions:
  1. With the device powered ON, insert the SD card into the device
  2. Highlight Manage Card and press the Select button
  3. Highlight either Merge From Card or Replace From Card and press the Select button
    • Merge From Card will add the data from the SD card to the existing data saved to the internal memory of the device
    • Replace From Card will delete the data already saved to the internal memory of the device and overwrite it with the data from the SD card
  4. Highlight USER DATA and press the Select button
The data will now be copied from the card to the internal memory of the device and can be used at any time.
