Active Lane Guidance
Active Lane Guidance is a feature that takes Lane Assist and Junction View to the next level. When on a route that contains an area compatible with Active Lane Guidance, the device will switch to a split-screen view.
On the left will appear the standard map, indicating your route as usual. The right half of the screen will display a moving lane animation with a purple line that will indicate the way the driver should navigate.
Some devices will display Junction View as an overlay in the top right of the map screen.
Active Lane Guidance helps you stay on top of your route so you can ensure you're in the correct lane with plenty of time to spare, avoiding potentially dangerous last-minute maneuvers.
