Changing the Text Language on an Automotive Device if you can't Read it
You can change the text language if a device is in a language you cannot read (wrong language).
A Video Tutorial can be Viewed which is a Quick and Easy way to Learn about Changing the Text Language:
To Change the Text Language:
When the device is first powered on a product usage agreement screen will appear briefly. Select the Accept button at the bottom.
1. Touch the Gear icon on the screen with the magnifying glass and map icons
2. Touch the down arrow
3. Touch the "ABC" blocks icon
4. Touch the second option from the top
5. Touch the up or down arrow until you find the desired language
6. Touch the desired language to select it
7. Touch the lower right-hand button to Save
The device should now be in the selected text language.
See your owner's manual for instructions on changing your device's keyboard or voice language(s).
