(2025) Service Advisory 25016 Rev A: Integrated Avionics System Search and Rescue Pilot’s Guide
PRODUCTS AFFECTED:
The Integrated Avionics System Search and Rescue Pilot’s Guide (190-00760-00) is affected.
ISSUE:
The following must be noted in reference to the ‘waypoint to anchor the search pattern’ for the following SAR enabled aircraft:
- Cessna Citation M2/CJ3+ with G3000® Flight Deck SysRel 7.51.X (GDU 32.61)
- Cessna Latitude and Longitude with G5000® Flight Deck SysRel 7.51.X (GDU 32.61)
The waypoint for the destination airport must not be used to anchor the search pattern. If the search pattern is desired at the destination airport, the destination must be entered in the enroute portion of the flight plan, and then the search pattern anchored to this waypoint.
