How Do I Enable Pairing Mode on My HRM 200?
If pairing your HRM 200 using a secure connection, the HRM 200 will need to be in pairing mode.
Tip: Hold the HRM 200 in your hands so you can easily see the button (1) and LED (2). (The HRM will only go to sleep after two minutes of not being worn and no button presses.)
HRM 200
To put HRM 200 in pairing mode:
  1. Press the button to wake the HRM. The LED will double blink every 5 seconds when in secure mode.
  2. Press and hold the button for 4 seconds. The LED will start flashing orange continuously indicating it is in pairing mode.
Note: Pairing mode lasts for 5 minutes or until the HRM forms a secure connection.
You can manually exit pairing mode by pressing and hold the button for 4 seconds.
Related
