Open the Garmin Connect app.
Open the menu.
Android: Select
(top left)
iOS: Select More (bottom right)
Select Garmin Devices.
Select your Garmin device.
Select General.
Select Wi-Fi Networks.
Select Add a Network.
Select the network you wish to add.
Select Connect in the pop-up window.
Select OK once connected.
Setting Up or Troubleshooting a Wi-Fi Connection on a Fitness Device
Fitness devices that can connect to a Wi-Fi network allow you to automatically upload saved activities and download available software updates when in range of the network. You will want to first verify if your device is compatible with the Wi-Fi feature.
What Requirements Does My Wi-Fi Network Need to Meet?
null
How to Add a Wi-Fi Network to a Garmin Device
To configure the Wi-Fi settings on your device, you can use either Garmin Express or the Garmin Connect app. Select an option below to reveal instructions.
The following is a video on setting up Wi-Fi connectivity.
Why Does Garmin Express Prompt Me to Sign in Before Displaying My Wi-Fi Networks?
Garmin Express protects the Wi-Fi network credentials you have saved to your Garmin device by requiring you to sign in to your Garmin Connect account before displaying your Wi-Fi networks. After disconnecting your Garmin device from your computer, the next time you navigate to Tools & Content > Utilities in Garmin Express, you will be prompted to sign in again before Garmin Express will display your saved Wi-Fi networks.
Troubleshooting the Connection to the Wi-Fi with My Device
If you are having trouble connecting your device to a Wi-Fi network, below are some suggestions you can try to resolve this issue.
Ensure that Garmin Express indicates that the Wi-Fi network is set up.
Ensure the device software is up to date by syncing with Garmin Express.
Attempt to connect to a different available Wi-Fi network such as a personal Wi-Fi hotspot.
NOTE: Additional carrier fees may apply. Check with your service provider if you have any questions.
Remove the Wi-Fi network, and add it again from the beginning.
To confirm that the device is connected properly to Wi-Fi, follow the steps below:
NOTE: Disable Bluetooth if the device is paired to the Garmin Connect app. This will prevent the activity from being uploaded via Bluetooth instead of Wi-Fi.
Record and save a 20-second test activity on your Garmin device.
Wait approximately 30 seconds for the device to establish a Wi-Fi connection and transfer the activity.
If successful, the device will display a message indicating the transfer is complete.
If one minute elapses without the device displaying a message, check Garmin Connect to see if the activity appears.
If the activity appears in the Connect account, Wi-Fi is functioning properly.
