Honda Map Update USB Not Detected by Garmin Express on a Windows Computer
USB communication issues can prevent your USB drive from being detected by the Garmin Express™ software.
Before starting the map update process, visit https://honda.garmin.com/honda for instructions on preparing your USB flash drive for the map update process.
Using the Same USB Flash Drive for the Honda Map Update / Formatting the USB Flash Drive
When doing a Honda map update you may use the same USB flash drive that was used for a previous map update.  Prior to using the flash drive for the new update however, you will want to completely format the drive.
Once the flash drive has been formatted, you will want to follow the full update process found at https://honda.garmin.com/honda/
Ensure that Windows Recognizes the USB Drive
When a device is properly connected to a Windows computer, it will be displayed as a removable disk or portable device
To verify that Windows detects the USB drive:
1. Connect the USB drive to the computer
2. Press the Windows Key ()+ E
3. Click This PC (Windows 10 and newer)
The USB drive will be listed under Devices and Drives in Windows 10. In older version of Windows, the USB drive will be listed under Devices with Removable Storage.
USB Drive Does not Display as a Drive in Windows
Try the steps below if the USB drive does not appear as a drive in Windows or appears as an "unknown device" in the Windows Device Manager.
Ensure the USB port is Working Properly:
  • Try a different USB port on your computer and/or test the USB port with a different USB device
  • Avoid connecting through a USB hub, USB extension cable, keyboard, or monitor
  • On desktop computers, use the USB ports on the back of your computer
Disable USB Selective Suspend:
On Windows, USB Selective Suspend will limit power to connected USB devices, including your Garmin device. It can potentially cause recognition problems.
Contact your computer's manufacturer for instructions to disable USB Selective Suspend.
Restart the Computer and Try Again:
NOTE: Shutting down, pressing the power button, or closing the lid on a notebook computer may not effectively restart the computer on some operating systems. Follow the instructions below to ensure that the computer is completely restarted.
Windows 10 and Newer
    1. Right-click the Windows Icon Start button
    2. Click Power
      • Some computers may skip this step.
    3. Click Shut down or sign out
    4. Click Restart
See below for a Windows 10 example.
Windows 8.1 and 10 Restart
USB Drive is Recognized by the Computer but not by Garmin Express
Ensure Garmin Express is Up to Date:
  1. Click Settings in Garmin Express
  2. Click About
  3. Click Check for Updates to Express
  4. If there is an update available, click Install Now and follow the prompts to complete the update.
null
If your Device has Already been Added to Garmin Express, Try Removing the Device and Adding it Back Again:
  1. Click Home
  2. Right-click your device
  3. Click Remove from Express
  4. Click Remove
  5. Click Add a Device
  6. When the device is found, click Add Device
  7. Follow the on-screen prompts to add your device back to Express
Uninstall and Reinstall Garmin Express:
To uninstall Garmin Express from the computer, see  Full Uninstall of Garmin Express
Once Garmin Express has been uninstalled, the latest version can be re-downloaded by visiting https://www.garmin.com/express
Restart the Computer:
    2. Click Power
    4. Click Restart
If These Steps did not Resolve the Issue:
Visit Related Content at the bottom of this page or the Garmin Express section of Support Center and you will find the available Product Support contact options in the Contact Us for More Help section.
Related
