Garmin Velocity Made Good (VMG): Waypoint VMG and Wind VMG
Garmin chartplotters can compute and display Waypoint VMG and Wind VMG.
VMG: Velocity Made Good (VMG)
Waypoint VMG: A measurement of how fast a vessel travels either toward or away from an active waypoint. Waypoint VMG is a function of the GPS. If the Waypoint VMG value displays as a negative number, the vessel is moving away from the active waypoint
Wind VMG: A measurement of how quickly a ship moves toward or away from the wind direction. If the Wind VMG value displays a negative number, the vessel is moving away from the wind
The following chartplotters running the latest software version can display Waypoint VMG using the navigation functions Go To, Route To, and Auto Guidance+™ technology.
GPSMAP® 7x2 chartplotters | GPSMAP® 7x3 chartplotters | GPSMAP® 9x2 chartplotters | GPSMAP® 9x3 chartplotters | GPSMAP® 10x2 chartplotters | GPSMAP® 12x2 chartplotters | GPSMAP® 12x3 chartplotters |GPSMAP® 16x3 chartplotters | GPSMAP® 74xx chartplotters | GPSMAP® 76xx chartplotters | GPSMAP® 84xx chartplotters | GPSMAP® 86xx chartplotters | GPSMAP® 8700 chartplotters | GPSMAP® 90xx chartplotters | GPSMAP® 92xx chartplotters |MFD A7 | MFD A12
ECHOMAP™ Plus 7x chartplotters | ECHOMAP™ Plus 9x chartplotters | ECHOMAP™ UHD 7x chartplotters | ECHOMAP™ UHD 9x chartplotters | ECHOMAP™ UHD2 7x chartplotters | ECHOMAP™ UHD2 9x chartplotters |ECHOMAP™ Ultra chartplotters | ECHOMAP™ Ultra 2 chartplotters
Waypoint VMG:
Devices Required to compute Waypoint VMG:
Compatible chartplotter
- GPS Speed (SOG)
Wind VMG
Devices Required to compute Wind VMG:
Wind transducer connected (wired or wireless) to the NMEA 2000 Network
A Speed Source: A GPS for Speed Over Ground (SOG) or a Paddle Wheel for Boat Speed (BSP) connected to the NMEA 2000 Network
A compatible Garmin chartplotter
A GNX™ wind instrument or GMI™ 20 marine instrument will only display VMG when navigating a route, a chartplotter is needed to show the overlay.
