Data Loaded to an SD Card an Automotive Device will Recognize
Garmin Automotive Devices will Read a Variety of Data from an SD card. The Recognized Data Types are Listed Below:
Garmin map image files loaded to the card from Garmin Express™ application, Garmin BaseCamp™ application, or through Garmin's downloadable web content.
User-created routes for devices supporting multiple-point routing.1,2
These files do not require you to keep the memory card installed in the device once imported.
Files will be imported to the internal storage.
Waypoints1 and custom Points of Interest (POI) files.
1 Some devices require you to import routes and waypoints before they will appear on the device.
For most GPS navigators, see Viewing Routes Transferred from the Computer on an Automotive Device.
For the Garmin Drive 53 Series, Garmin DriveSmart™ 66, Garmin DriveSmart™ 76 and Garmin DriveSmart™ 66, Garmin DriveSmart™ 76, Garmin DriveSmart™ 86 with Amazon Alexa GPS navigators, see Viewing Routes Transferred from the Computer on an Automotive Device.
For the dēzl™ OTR610, dēzl™ OTR620, dēzl™ 710, dēzl™ 720, dēzl™ 810, dēzl™ 820, dēzl™ 1010, dēzl™ 1020, dēzlCam™ OTR710, dēzlCam™ OTR725, Garmin DriveCam™ 76, RV 795, RV, 895, RV1095, and RVcam 795 GPS navigators, see Viewing Routes Transferred from the Computer on an Automotive Device.
- NOTE: Garmin BaseCamp™ is not compatible with the dēzl OTR620, dēzl OTR720, dēzl OTR820, dēzl OTR1020, and dēzlCam OTR725
2 GPX files must be located in a "GPX" folder within a "Garmin" folder on the SD card. You can create these folders manually when the SD card is connected to your computer.
