D2™ Mach 1 | D2™ Mach 1 Pro watches
Descent™ G1| Descent™ G1 Solar | Descent™ G1 Solar - Ocean Edition watches
Descent™ G2
Descent™ Mk1 watch
Descent™ Mk2 | Descent™ Mk2S | Descent™ MK2i watches
Descent™ Mk3 | Descent™ Mk3i watches
Descent™ X50i dive computer
Enduro™ watch
Enduro™ 2 watch
Enduro™ 3 watch
epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire Edition | epix™ (Gen 2) - Porsche Edition watches
epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire Edition watches
fēnix® 3 | fēnix® 3 HR | fēnix® 3 Sapphire watches
fēnix® 5 | fēnix® 5S | fēnix® 5X watches
fēnix® 5 Plus | fēnix® 5S Plus | fēnix® 5X Plus watches
fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition watches
fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition watches
fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition watches
fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition watches
fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition watches
fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition watches
fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition watches
fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition watches
fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition watches
fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition watches
fēnix® E watch
fēnix® Chronos watch
Forerunner® 255 | Forerunner® 255S | Forerunner® 255 Music | Forerunner® 255S Music watches
Forerunner® 265 | Forerunner® 265S watches
Forerunner® 735XT watch
Forerunner® 745 watch
Forerunner® 920XT watch
Forerunner® 935 watch
Forerunner® 945 | Forerunner® 945 LTE watches
Forerunner® 955 | Forerunner® 955 Solar watches
Forerunner® 965 watch
Garmin Swim™ 2 watch
Instinct® 2 - Standard Edition | Instinct® 2 - Camo Edition | Instinct® 2 - Surf Edition | Instinct® 2 - dēzl Edition watches
Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition watches
Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition watches
Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition watches
Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition watches
Instinct® 3 - AMOLED | Instinct® 3 - Solar watches
Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition watches
MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer watches
MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2) watches
MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition watches
quatix® 5 | quatix® 5 Sapphire
quatix® 6 | quatix® 6 Titanium | quatix® 6X Solar watches watches
quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition | quatix® 7 Pro watches
tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition watches
tactix® 8 - AMOLED | tactix® 8 - Solar watches
tactix® Charlie watch
tactix® Delta - Solar Edition |tactix® Delta - Solar Edition with Ballistics | tactix® Delta - Sapphire Edition watches
How Does the Store and Forward Feature on My Heart Rate Strap Work?
Select heart rate monitor (HRM) straps feature the ability to store up to 18 hours of heart rate data and forward it to a watch later. The feature is used for when your paired watch cannot receive data in real-time or when is it out of range of the HRM strap. Examples include when you are swimming or when the watch is taken off during team sports or martial arts.
Heart Rate Monitor Straps With the Store and Forward Feature
HRM-Fit™
The HRM-Fit™ monitor is not designed to be used for swimming.
HRM-Pro™
HRM-Pro™ Plus
HRM-Swim™
HRM-Tri™
Using Store and Forward
To use store and forward, put on your HRM strap and start a timed activity on your watch. At the end of the activity, the watch will automatically begin searching for stored heart rate data and download it from the HRM strap if the following occurred:
There was an HRM strap paired to the watch when the activity was started.
There is missing heart rate data from the recorded activity.
NOTE: Store and Forward should not be used for any activity when your watch is receiving real time heart rate throughout, such as running or cycling.
The Data From My Strap Was Not Downloaded to My Watch
NOTE: The Store and Forward feature will only provide heart rate data. Other data such as Running Dynamics, respiration rate, steps, and some physiological metrics like VO2 max or stamina require the watch and heart rate monitor to be connected and remain in range during the entire activity.
To handle any cases where stored heart rate data was not downloaded post-activity, there is an option to manually cue the watch to download heart rate.
Manually Downloading Heart Rate Data to a Watch
Put the heart rate strap on.
From the watch, access the settings menu.
Select History.
Select the Activity.
Select Download Heart Rate.
When heart rate data is manually downloaded, a second activity file is created with the stored heart rate. You may have to manually upload this second file to the Garmin Connect™ online network. This will result in having two of the same activities: one without the stored heart rate and one with the heart rate. The activity that does not display heart rate data can be deleted. For help with uploading an activity manually into Garmin Connect or deleting an activity from your Connect account see Related below.
