How to Find the Software Version of Garmin Power Meter Pedals
The software version currently installed on a Rally or Vector system can be viewed on your paired Garmin device. Select your device below to reveal instructions.
NOTE: Spin the pedals a few rotations to wake the pedals up. They must be awake and connected in order to view software information.
Edge 500
  1. Press and hold the PAGE/MENU button to open the Menu.
  2. Select Settings.
  3. Select Bike Settings.
  4. Select your Bike Profile.
  5. Select ANT+ Power.
  6. Select About.
Edge 510 and 810
  1. Touch the Tools icon from the Main Menu.
  2. Select Bike Profiles.
  3. Select the profile for the bike that the power meter is installed on.
  4. Select Power (dumbbell icon).
  5. Select Sensor Details.
  6. Select About.
Edge 520 and 520 Plus
  1. Press the up button from the Main Menu to go to the Status menu.
  2. Select the Sensors menu.
  3. Select the paired pedals.
  4. Select Sensor Details.
Edge 530
  1. From the main screen select the Menu icon.
  2. Select Sensors.
  3. Select the power meter icon.
  5. Select About.
Edge 800
  2. Select Bike Settings.
  3. Select Bike Profiles.
  4. Select the profile for the bike that the pedals are installed on.
  5. Select ANT + Power.
  6. Select Sensor Details.
  7. Select About Sensor.
Edge 820
  1. Touch the Menu icon.
  2. Select Settings.
  3. Select Sensors.
  4. Select Power Meter.
Edge 1000, Explore 1000
  2. Select Sensors.
Edge 1030 Series and 830
  1. Touch the Options icon from the Main Menu.
  2. Select Sensors.
Edge 130 Series
  1. Press and Hold UP.
  2. Select Sensors.
  3. Select Paired pedals.
  4. Select Information.
  5. Select About.
Forerunner 735XT
  1. Press the Start/Stop Button.
  2. Select Settings.
  3. Select Sensors and Accessories.
  5. Select About.
Forerunner 910XT
  1. Press and hold the MODE button to put the device into Bike mode.
  2. Press the MODE button to open the Main Menu.
  3. Select Settings.
  4. Select Bike Settings.
  5. Select your Bike Profile.
  6. Select ANT + Power.
  7. Select Sensor Details.
  8. Select About.
Forerunner 920XT
  1. Press the Menu button to go to the Main Menu.
  2. Select Settings.
  3. Select Sensors & Accessories.
  4. Select the paired pedals.
  5. Select About.
Forerunner 935
  1. Press and hold the menu key to access the menu of the watch.
  2. Select Settings.
  4. Select Power.
  5. Select About.
Forerunner 255 Series, 745, 945/945 LTE, and 955/955 Solar
  2. Press the arrow down key.  Under settings select Sensors & Accessories.
  3. Select Power.
  4. Select About.
You can also run the Vector Updater application (Vector and Vector 2) or use the Garmin Connect app (Rally and Vector 3). These two applications will report the current firmware on the Vector pedals, and allow you to update the firmware if a newer version is available.
