Why is My Approach S70 Battery Draining Quickly?
Your Approach® S70 watch can perform a variety of functions, and any function the watch performs will require some power from the battery. Some functions, and how often you use them, will require more battery than others.
Why is My Watch Battery Draining Quickly?
If your watch has a shortened battery life, here are some troubleshooting steps we recommend.
Fully charge your watch to see if the issue has been resolved.
If your watch continues to drain battery quickly, check any recently adjusted settings that could contribute to a higher battery use. For help adjusting watch settings, see the
How Can I Get More Battery Life?
section below.
If your battery is being used faster than expected, or not lasting as long as it used to, read the information below to learn about settings and features that have a greater impact on battery usage.
Adjust Settings
The default settings for your watch were configured to balance performance with battery life. Changed settings may be the cause of increased battery drain. If you forgot the settings you changed, you can restore the default settings for your watch. For help see,
Reset Default Settings
NOTE: Settings for the options listed below are located in the watch menu. Refer to your owner's manual for feature compatibility, and exact setting location.
Pulse OX: Using During Sleep mode with the pulse oximeter will use the battery at a higher rate. To conserve battery life, it is recommended to set the mode to Manual Check. The watch will only analyze your oxygen saturation when you view the pulse oximeter widget.
Display: How bright the display is set and how often it comes on can use battery more quickly or less quickly. Having the display set at max will use a lot of battery while the display is on. Try adjusting the Display settings, and turn off Always On to find a balance for battery usage.
GPS: When enabled you will see a higher battery use, which is why GPS tracking is only activated during a round of golf or activities.
Music: Controlling music being played on your phone, downloading music over Wi-Fi, and playing music stored on the watch will contribute to higher battery use. We recommend charging your watch while downloading music.
Bluetooth: Occasional text notifications and use of other connected features will drain far less battery than continually receiving texts, answering the phone, running a music player, or getting weather updates.
Connected Sensors: Additional connected sensors like heart rate monitor chest straps or Bluetooth headphones all require additional power from the watch to stay connected.
Watch Face: Some watch faces, apps, widgets, and data fields may draw more power depending on how many things they do or whether they use GPS positioning or not.
Widgets: Some widgets update data when you select them, like weather. Widgets like Altimeter, Barometer, and Compass (ABC sensors) are always active.
Press Menu.
Select Settings.
Select System.
Select Reset.
Select Reset Default Settings.
Select the checkmark to confirm.
If your watch is paired to your phone, you will need to pair the watch back to the phone after resetting. For help on pairing your watch to your phone, refer to your owner's manual. For additional resources on pairing your watch, see - Garmin Golf App Troubleshooting.
Significant battery use can sometimes occur if an activity or another feature is left running in the background. See Stopping an Activity for steps on how to stop an activity on the watch.
Otherwise, you can try the following steps to perform a power cycle:
Hold MENU button.
Select .
Once off, hold MENU button to turn the watch on.
Is Your Watch Battery Still Draining Quickly?
After attempting the above troubleshooting if you still see significant battery use, we recommend contacting Product Support to help determine what is using the battery.
Some information to help Product Support determine what might be using the battery more than expected:
Is the display set to Always On, and is Gesture enabled?
How often are you performing GPS activities or golf rounds, and how long are they?
Is Pulse Ox enabled? If so, what is it set to?
What is the battery estimate in days on a full charge, and how fast does it take to completely drain the battery?
What kind of watch face are you using? Does it display current heart rate?
