You are viewing an article that is not available in your currently selected language. You can choose another one below.
Removing Garmin Software and Garmin Registry Keys in Windows for an Automotive Device
Garmin software is removed from Windows using the standard uninstall procedure for Windows.
To Remove Garmin Software:
- Press the Windows key + R
- Type appwiz.cpl
- Click Ok
- Right-click on the name of the application to remove
- Select Uninstall
- Follow the on-screen prompts (if necessary)
IMPORTANT: Removal of Garmin registry keys is not necessary under normal circumstances and should only be performed for troubleshooting purposes or for a complete uninstall. Using Registry Editor incorrectly can cause serious problems that may require Windows to be reinstalled. Use Registry Editor at your own risk.
To Remove a Garmin Application From the Registry:
- Type regedit
- Click OK
- Back up the registry1
- Expand HKEY_CURRENT_USER to show folders
- Expand Software
- Expand the Garmin folder
- Right-click the folder for the application being uninstalled
- Click Delete
- Click Yes to confirm
- Click the arrow next to HKEY_CURRENT_USER to collapse folders
- Expand HKEY_LOCAL_MACHINE
- Expand Software
- Expand Wow6432Node (This step only applies to 64-bit operating systems)
- Click Delete
- Close the Registry Editor
- Restart the computer
The Garmin software is now removed from the computer.
1To Back Up the Registry:
- In the Registry Editor, right-click (My) Computer at the top of the left-hand column
- Click Export
- Browse to the C: drive
- Enter Gregistry for the name and click Save
The registry will now be backed up.
Consult a Microsoft Certified Repair Technician if the above steps don't work.
