Satori Smart Trainer Features
Below are details regarding the features of the Satori Smart trainer that will have influence on your indoor cycling experience.
Flywheel
The Satori Smart is equipped with a 1,6kg (3.52 lbs.) flywheel. The weight of the flywheel in combination with the rotational speed creates a large inertia. This inertia ensures the smoothness of cycling you would expect.
Manual Resistance Control
Satori Smart features a handlebar mounted lever allowing you to increase resistance up to 10 different levels from 100 watts to 950 watts.
Measure Speed and Cadence
In addition to power, Satori Smart can measure speed and cadence.
Take Satori Anywhere
Satori Smart is powered by two AA batteries and does not need an external power source. Batteries will last up to one year before they need to be changed.
