Using Rescue Mode on the Pro 550 Plus
Rescue Mode
You can turn on rescue mode to conserve battery power at the end of the a long hunt or if your dog might get out of range. After you turn rescue mode on, it stays on until you turn it off. When the collar battery power falls below 25%, the collar data updates only once every 2 minutes.
On the handheld:
  1. Switch your toggle to the desired dog (black, red, blue).
  2. Turn Dial to N.
  3. Select the Tone button.
  4. Use the training keys to scroll through the list.
  5. Use the Tone button to select Rescue Mode.
  6. Select Enable or Disable by pressing the Tone button.
