How to Replace the Mounting Tabs on Edge 540 | 840 Series
The mounting tabs on the back of the following Edge Cycling computers are user-replaceable:
  • Edge® 540 | Edge® 540 Solar
  • Edge® 840 | Edge® 840 Solar
replacement tabs on edge 540 or 840
Required Tool:
  • Size 0 Philips Screwdriver
Replacement Part:
Part number S00-02030-00 can be purchased from Garmin here.
Steps to Replace:
  1. Using the Size 0 Philips screwdriver, remove the mounting tab by removing the two screws holding it in place.
  2. Place the new mounting tab on and secure using the new screws.  New screws will have a thread-locking adhesive applied to the threads.
  3. To ensure the screws tightened enough, there should be no movement between the tabs and Edge.
    testing tabs for tightness
Mounting Tab Replacement Video:
