Getting Started With Outdoor Maps Plus Subscription
With an Outdoor Maps+ annual subscription,1 you gain access to a wide variety of premium global mapping content. This content is regularly updated and the one subscription can be activated and downloaded directly to any of your registered compatible Garmin devices simultaneously via Wi-Fi, as well as the Garmin Explore app2 or Tread® app.
To access Outdoor Maps+ content, you must have a compatible device. To check device compatibility before purchasing, see - Compatible Garmin Devices.
Select your product series below for details on how to activate, download, and use the different types of mapping content that are available with Outdoor Maps+.
To purchase an Outdoor Maps+ annual subscription, visit Outdoor Maps+ Annual Plan.
1 Subscription begins when purchased and you will need to renew after 1 year.
2 A Garmin Explore app Compatible device is required, device map compatibility isn't required
3 These instructions apply to the Alpha 200 Plus handheld also
4 These instructions apply to the Alpha XL navigator also
