My Approach Z80 is in the Wrong Language
If your Approach® Z80 laser range finder is set to the wrong language and you need to change it, the below instructions will guide you through selecting the correct language. If the language is incorrect on your first usage of the watch, follow the steps for resetting the device.
Changing the Language
Power on the Approach Z80, then press two times
Press
Press three times
Press
Press
Select your desired language
You have now changed the language on your Approach Z80 range finder.
If you were unable to change the language on your watch using the steps above, select the option for Resetting below and follow those steps to reset your range finder. You will be prompted to select a language after the reset, during initial setup.
Factory Reset
Power off the Approach Z80, then press and hold and
Press and release Power/
When the light turns purple, release
When the light turns red, release
The Approach Z80 range finder will now reset, and a new language can be selected during the initial setup.
