Getting Started with the tactix Delta Solar
Below is a list of articles that will help you get started with, and get the most out of, your new Garmin tactix® Delta Solar watch.
How Do I Get Started?
Before getting started, we recommend that you fully charge your tactix Delta Solar watch. See Charging the Device to learn how.
1. Power on the tactix Delta Solar by holding the Light button.
Click Here to Learn About the Buttons
Tactix Delta Solar Overview
2. Choose your language by scrolling through the list, use with the Start/Stop button to select your language.
3. Pair your watch with your smartphone following the on-screen instructions (optional).
 Click Here for Help With Bluetooth Pairing
4. The next steps allow you to set your user preferences, simply follow the on-screen prompts to complete the setup process.
How to Record Your First Activity
To start using activities, choose your preferred activities.
1. Press the Start/Stop button
2. Locate your activities by using the Up or Down buttons to scroll through the list. Press Start/Stop button to select the activities
3. Use the Down button until you see Done on the screen. Press the Start/Stop button to save your selections
4. To start using activities, see: How to Start an Activity
Tip: If you want to add activities, see: How to Add an Activity to the Garmin tactix Delta Solar
Other Articles You Might Find Useful
