inReach Mini 2 Menu Options
The home page and widget glances on the inReach® Mini 2 handheld contain all the information you need to operate your device. You can press Up Button or Down Button to scroll through the widget glances and view summary data for each, and you can press OK to view more information for a widget glance.
The information below explains what settings and options are available for the home page and each of the widget glances.
Home Page
Displays the date, time, and status icons. It also displays tracking and weather information when those features are in use. The main menu can be accessed from this page to adjust most settings on the inReach Mini 2 handheld.
inReach Mini 2 Home Page
Press OK to open the main menu. Select "Complete List of Main Menu Options" below to see all of the main menu options and their sub-menus. For more details on what each of these settings and options are used for, refer to your owner's manual.
NOTE: If your inReach Mini 2 handheld is missing some of the menu options listed below, update the software. For instructions, see - Updating the Software on Your inReach Mini 2.
inReach Mini 2 Menus
Main MenuSub-Menu 1Sub-Menu 2Sub-Menu 3Sub-Menu 4
Send Message →
Select and/or Type Contact  →
Type MessageSend
Select Quick Text
Check-In →
Select a Check-In →
Send
Start Tracking →
Stop Tracking  →
Save
Discard
Back to Start
Share With →
Select and/or Type Contact  →Type MessageSend
Select Quick Text
Settings →
Send Interval
Activity Recording
Auto Track
Navigate →
Waypoints →
Select a Waypoint →Press OKGo
Pan/Zoom Map
View Details
TracBack →
Select a time range →Select a point →Follow Path
Straight Line
Coordinates →
Follow prompts to enter coordinates
Sight 'N Go →
Follow prompts to set the heading
Courses →
Select a Course →Press OKGo
Reverse Course
Pan/Zoom Map
View Details
Activities →
Select an Activity →Press OKGo
Back to Start
Pan/Zoom Map
View Details
Mark Waypoint →
Press OK
Edit Details
Delete
Contacts →
Add Contact →
(select an item to enter details)
Select a Contact →
Press OKEdit Details
Delete
Service Plan →
Test Service
Plan Details
Press OK for Update Details (used to check for recent data plan changes made on explore.garmin.com)
Data Use →
Check-Ins Sent
Messages Sent
Points Sent
Saved →
Waypoints →
Export to GPX
(exports all waypoints to GPX)
Select a Waypoint →
Go
View Details
View on Map
Edit Details
Delete
Courses →
Select a Course →Go
Reverse Course
View Details
View on Map
Export to GPX
Delete
Activities →
Select an Activity →Go
Back to Start
View Details
View on Map
Export to GPX
Delete
Settings →
Tracking →
Send Interval
Activity Recording
Auto Track
Sounds →
Mute All
Volume
Ring Until Read
Message Rec.
Message Sent
Critical Alert
Power Off
Map →
Waypoints (Show/Hide)
Waypoint Labels (Show/Hide)
Track Points (Show/Hide)
Messages (Show/Hide)
Auto Zoom (On/Off)
Orientation →
North Up
Track Up
Phone →
Status (Connected or Waiting for Phone/Off)
Connected Device
(Phone Name)
Pair Phone
inReach Remote →
Status (On/Off)
Device Number
Verification (On/Off)
System →
Backlight →
Brightness
Timeout
Compass Cal.
Time →
Time Format
Time Zone
Daylight Saving (this option will not appear if Time Zone is set to Automatic)
Units →
Position Format
Speed/Distance
Wind Speed
Temperature
Pressure
Bearing
GPS →
GPS Only
Multi-GNSS
Language →
(select a language)
Keyboard Language →
(select a language)
Owner Info →
(enter owner info)
USB Mode →
Garmin
Mass Storage
External Power
Auto Off (On/Off)
Screenshots (On/Off)
Reset Device →
Reset Default Settings
Delete Data and Reset Settings
Software Update
Check for Updates
Prompt at Boot (On/Off)
About
Back to Top
Messages
Press OK to view your message history, send a new message, or reply to a message. For more details, see - Writing a Message on the inReach Mini 2.
Messages Widget Glance
Back to Top
Tracking
Press OK to start and stop tracking or view the progress of ongoing tracking. For more details, see- Getting Started with Tracking on an inReach Mini 2.
Tracking Widget Glance
Back to Top
Navigation
Press OK to view the map and compass or begin navigating. For more details, see - Navigating With Waypoints, Courses, and Activities on the inReach Mini 2.
Navigation Widget Glance
Back to Top
Weather
Press OK to view the last weather forecast or request an updated weather forecast. For more details, see - Requesting Weather Forecasts With an inReach Mini 2.
Weather Widget Glance
Back to Top
Message Check
Displays when the last mail check was done. The inReach Mini 2 handheld will listen for new messages for 10 minutes after you send a message, and then again every hour. Press OK to force a check for messages.
Message Check Widget Glance
Back to Top
