SD Memory Card Compatibility for Garmin Dash Cam 45 and 65W
Garmin Dash Cams require an SD card to record video or take pictures because the device does not have any internal memory for storing files.
SD Card specifications for Garmin Dash Cam™ 45 and Garmin Dash Cam™ 65W:
Minimum Capacity | Maximum Capacity | Card Types | Speed Class |
4 GB | 64 GB | microSD, microSDHC, microSDXC | Class 10 (or higher) is required |
SD/microSD cards can be purchased from Garmin or other retailers.
SD memory cards wear out after they are overwritten a large number of times.
- Your device detects memory card errors automatically and alerts you when it is time to format or replace your memory card.
To help extend the useful life of your SD card, Garmin recommends the following:
Back up saved footage and format the memory card at least once every 6 months.
Transferring saved footage, see your device's Owner's Manual.
Replace the memory card periodically due to the dash camera recording continuously.
Turn off the device when your vehicle is not in use to prevent the dash camera from recording unneeded footage.
Use an authentic memory card with a higher storage capacity.
Higher-capacity memory cards are overwritten less frequently and will usually last longer.
Use a high-quality memory card with a speed rating of Class 10 or higher.
Purchase your replacement memory card from a high-quality manufacturer and a reputable vendor.
The Following SD cards have been Tested and Verified to work with the Garmin Dash Cam 45 and Garmin Dash Cam 65W.
SD cards not listed may or may not work with your device. Class 10 is required.
SD Card Brand | Specs | Size |
ADATA | UHS-I | 16GB and 32GB |
Transcend | High Endurance | 16GB and 32GB |
Toshiba | Exceria UHS-I | 16GB and 32GB |
Kingston | EVERPRO UHS-I U1 | 32GB |
When choosing a memory card, select one specifically designed for dash cams. These cards offer greater endurance and can withstand continuous read-write cycles. Additionally, they are engineered to handle the extreme temperatures and vibrations commonly encountered in a vehicle.
NOTE: To prevent damage to the slot, always use authentic microSD cards that meet the thickness specification of 0.7mm ± 0.1mm.
Memory cards that may serve this purpose include those listed below. Before making a decision, it’s advisable to examine the manufacturer’s specifications and warranty to ensure that the product aligns with your intended purpose.
Brand | Family |
ADATA | High Endurance |
Samsung | Pro Endurance |
SanDisk | High Endurance Max Endurance |
Note that if a memory card is used in a way that is not recommended by its manufacturer without being specifically designed for it, such as use in a high-endurance environment like a dash cam, the manufacturer's warranty might not cover any resulting failure or replacement.
