Power Mount Installation FAQ's
What eBikes Are My Power Mount Compatible With?
The Edge Power Mount is compatible with most Bosch and Shimano eBikes, and most eBikes with a USB-A port in the cockpit area.
Where Does My Power Mount Cable Connect?
Both the Shimano and Bosch cables are designed to connect to your eBike’s headlight port. In the event you also have a headlight connected to this port already, you may not be able to install the cable. Consult with your local authorized eBike technician for further troubleshooting.
I Am Not Sure How to Connect My Power Mount to My Bike.
When in doubt, please contact your local authorized eBike technician for help with installation.
What Shimano eBike Drive Units Are Compatible With Edge Power Mount?
Most Shimano eBike drive units are compatible with the Shimano Power Mount accessory cable. Some may require an additional light port adapter. Contact your local authorized eBike technician for further information.
What Bosch eBike Drive Units Are Compatible With Edge Power Mount?
The Bosch Power Mount Cable is compatible with Bosch Generation 2 motors.
I Don’t Have an eBike but I Still Want to Use the Power Mount. How Do I Do That?
The Power Mount USB-A cable allows you to power your compatible Edge device from an external battery bank.
