What are my Options for Connecting FUSION Remote Controls to FUSION Stereos?
MS-NRX200 Marine Wired Remote Controls can be installed throughout the vessel to provide full control of multiple FUSION marine stereos, creating flexible zone control and NMEA2000 monitoring solutions. The MS-NRX200 is a plug-and-play device with two connection options:
1) STANDARD FUSION INSTALLATION – USING THE CABLE KIT SUPPLIED WITH YOUR NRX200 REMOTE CONTROL.
Connect the remote control to your FUSION Marine Stereo with the standard cable kit provided with your purchase. The standard cable kit supplied with your product is NOT NMEA 2000 compatible.
CONTENTS OF THE BOX
1 x 6M Extension Cable
2 x T-Connector
1 x Terminator (Male)
1 x Terminator (Female)
Note: If you install the remote control using the standard FUSION cable kit provided with the remote control, NMEA2000 repeater functions will not be available.
2) NMEA2000 INSTALLATION
An existing NMEA 2000 network can be used to connect the remote control to your FUSION Marine Stereo. FUSION NMEA2000 connection kits are available separately for this purpose.
The FUSION cable kit MS-N2KCONN will be required for each FUSION device connected to the NMEA2000 network.
MS-N2KCONN - NMEA2000 Connection Pack
CONTENTS OF THE PACK
1 x NMEA2000 T-Connector
1 x Drop Cable FUSION to NMEA2000 Micro-C5
The remote control can be configured to display available NMEA2000 data on the network such as water depth, vessel speed and basic navigation data. Refer to the section "What NMEA 2000 data does my NRX200 Remote Control display?" for a full list of NMEA 2000 sentences displayed by the remote control.
