Using the Trap Mode Without a Trap Range on the Xero S1
If you decide to try to use your personal electronic launcher for Trap Mode on the Xero® S1 trapshooting trainer keep in mind that it may not be as accurate. When pointing the Xero S1 trainer at the launcher at the appropriate distance ensure no portion of the tray house or a clay thrower out in front of the Xero S1 trainer is visible above the top edge of the alignment box of the launcher. It is also best to ensure you are on level ground between the launcher and the Xero S1 trainer.
