Getting Started With the quatix 7
When setting up a quatix 7 for the first time, the following steps walk you through the process to help get the most out of the watch.
Setting up the quatix 7
When powering on the quatix 7 for the first time, a prompt will appear to configure user setting and preferences on the watch. These settings can be changed at any time.
  1. Power on the quatix 7 by holding Light
    Learn About the Touchscreen and Buttons
    fenix 7 button layout
    one instruction TOUCHSCREEN
    • Tap to choose an option in a menu
    • Hold the watch face data to open the associated widget
    • Swipe up or down to scroll through the widget loop and menus
    • Swipe from left to right to return to the previous screen
    • Cover the screen with your palm to return to the watch face and turn down the display brightness
    two instruction LIGHT
    • Press to turn on the watch
    • Press to turn the backlight on and off
    • Quickly press twice to turn on the screen to use your watch as a flashlight
    • Hold to view the controls menu
    three instruction UP/MENU
    • Press to scroll through the widget loop and menus
    • Hold to view the menu
    four instruction DOWN
    • Hold to view the music controls from any screen
    five instruction START/STOP
    • Press to view the activity list and start or stop an activity
    • Press to choose an option in a menu
    six instruction BACK/LAP
    • Press to return to the previous screen
    • Press to record a lap, rest, or transition during a multisport activity
    • Hold to view the watch face from any screen
    Enabling and Disabling the Touchscreen
    • To temporarily enable or disable the touchscreen, hold DOWN and START
    • To enable or disable the touchscreen during general use, activities, or sleep, hold MENU, select System > Touch, and select an option
  2. Select the watch language by scrolling through the list using Up and Down, press Start to select the language
  3. Pair the watch to a smartphone with the Garmin Connect app (optional)
    NOTE: Paring the watch with Garmin Connect will also register the watch
    Learn More About Bluetooth Pairing
  4. Proceed through the onscreen prompts to select preferences and user settings
  5. Set up the Activity Menu by selecting favorite activity types (optional)
    Learn How to Set Favorite Activities
    1. Press Start to access the Activity Menu
    2. Use Up and Down to scroll through the list of available activity types
    3. Press Start to select each activity to use
    4. Select Done when finished
Learn More About the quatix 7
The following articles will help you explore and use the many features of the quatix 7.
Connected Features
Music Features
Battery Features
Training Features
Customizing the quatix 7
