Automotive Device Showing a Computer Icon in the Car
Your device may show an icon of a GPS device connected to a computer tower when plugged into the vehicle. This icon means the device is in file transfer mode. This is used specifically for connecting to a computer.
This May be Due to the Following Reasons:
  • A USB Cable is Plugged into the Device Instead of the Garmin-Provided Vehicle Power Cable
    • This is the most common cause of this issue.
    • This causes the device to think it is plugged into a computer.
      • The device enters file transfer mode when connected to a USB port or cable since they provide less power to the device.
      • The amount of power it receives from the connected cable determines which mode it uses.
    • The USB cable is used for plugging the device into a computer for updates.
    • The Garmin vehicle power cable plugs into a 12V outlet (cigarette lighter outlet) in most vehicles.
    • A High-speed Multi-charger can be used to charge other electronics at the same time you're using your device.
  • A Third-Party Cable is Being Used to Plug the Device into the Vehicle (Examples Below)
    • A mobile phone charger or adapter.
    • A "hard-wired" cable.
    • A 12V USB adapter manufactured by a different company.
See Using Third-Party AC Chargers, Cables, and Other Accessories with Garmin Automotive Devices.
  • In More Rare Cases, the Vehicle Power Cable or the USB Port on the Device May be Damaged
