index S2 Smart Scale - Reading and Recording Measurements
For the most accurate weight measurement, you should use the device on a hard, flat floor.
Each time you step on the device, it calculates your weight and other measurements. The LCD screen displays the calculated measurements automatically, moving to the next measurement every few seconds.
  1. Remove your socks and shoes.
  2. Tap the scale.
    The LCD display activates.
  3. Stand on the scale barefoot.
    Top view of the device with foot placement
    TIP: For best results, stand still with your feet placed flat on the glass surface of the scale.
    The scale displays your weight.
  4. When you see your initials, step off the scale.
    The scale displays additional measurements.
If you have set up your device with an active Wi‑Fi connection, measurements are uploaded automatically to your Garmin Connect account.
