Replacing the Buckle on a Garmin Quick Release Watch Band
Garmin® recommends that you take your watch to a jeweler if your buckle hardware needs to be replaced. The buckle of a compatible watch can be replaced with another buckle for a quick release 18mm, 20mm, or 22mm band, depending on your watch band size.
Since we offer so many color combinations, we may not offer a replacement band that offers the same color hardware as your original. Replacing the buckle should only be needed if you have purchased a new quick release band, and would like to use the same color of hardware that your old band had.
To replace your watch band buckle, you will need the following:
A Clean Workspace
Quick Release Band in the Correct Size For Your Watch
Replacement Buckle
Pin Removal Tool
Select an option below to see steps.
