GARMIN Customer Service Centre and Showroom will be relocated from Oct. 8th 2025 (Wed) to the new address: Room 1803-05, 18/F, 8 Observatory Road, Tsim Sha Tsui, Kowloon, HK
Mong Kok Service Centre and Showroom will be closed on Oct. 1st to Oct. 7th during the reallocation period.
My GPSMAP 78 Series is in the Wrong Language
If the wrong language is accidentally set up on the GPSMAP 78, use the directions below to correct the language. If the steps fail to resolve the issue, see Related for steps to reset the handheld. The reset process will prompt the user to select a language during setup.
Changing the Language
  1. Press the MENU key twice to open the main menu.
  2. Select Wrench.
  3. Select GPS Handheld.
  4. Scroll to and select the second item in the menu.
  5. Scroll to and select the desired language.
Related
