NOTE: ONLY Quickdraw Contours can be transferred onto a different micro/SD card.
NOTE: Preprogrammed or built-In charts or cartography CAN NOT be copied or transferred to another micro/SD card using this method. See the devices Owners Manual to "Copy Built-In Charts".
Users can transfer Quickdraw Contours from one micro/SD card to a different micro/SD card.
NOTE: Do not transfer Quickdraw Contour files onto a micro/SD card that already has an existing preprogrammed charts or cartography on that micro/SD card.
NOTE: Transferring Quickdraw Contour files onto a micro/SD card with an an existing chart or cartography may alter, damage, delete or distort the preprogrammed chart or cartography on the SD card.
Example of a SD card with a pre-programmed chart or cartography:
G2 / G3 Lake Vu
G2 / G3 Lake Vu Ultra (East or West)
G2 / G3 Vision charts
G3 Standard Mapping
Built-in update chart or cartography micro/SD card associated to your chartplotter
To transfer a users Quickdraw Contour files from one micro/SD card to different micro/SD card, follow these steps:
Insert the micro/SD card with the users Quickdraw Contours into a laptop / desktop computer micro/SD card slot
Identify and open the drive associated to the micro/SD card
Select the "GARMIN" File
Copy the entire "GARMIN" File
Paste the "GARMIN" file onto the other micro/SD card
See your Garmin fishfinder or chartplotter Owners Manual or Related Content to find out how to download existing Quickdraw Contours or share your Quickdraw Contours from the Quickdraw Contours Community.
