My Approach G6 Is in the Wrong Language
If your Approach® G6 golf handheld is set to the wrong language and you need to change it, the below instructions will guide you through selecting the correct language. If the language is incorrect on your first usage of the device, follow the steps for resetting the device.
Changing the Language
  1. Press the device key to enter the Menu
  2. Select Black Gear Icon on White Background
  3. Swipe up 2 times
  4. Touch the screen
  5. Swipe up 3 times
  6. Touch the screen
  7. Swipe until you see your language
  8. Touch the screen
You have now changed the language on your Approach G6 handheld.
If you were unable to change the language on your device using the steps above, select the option for a factory reset below and follow those steps to reset your device. You will be prompted to select a language after the reset, during initial setup.
Factory Reset
  1. Hold Power Button Symbol to turn off the device
  2. Place your finger on the top left corner of the touchscreen
  3. While holding your finger on the touchscreen, turn on the device
  4. Select Yes
If you had customized settings, you will need to make these changes again. Bring the device outdoors to a place with a clear view of the sky to connect to GPS satellites. This may take up to 20 minutes.
NOTE: Any scorecards saved to the device will remain on the device after a factory reset.
