What Are Cycling Dynamics?
Cycling dynamics are metrics and visual displays based upon data recorded by dual sensing Rally and Vector power meter pedals. This data is then transmitted and displayed on compatible Garmin Fitness and Outdoor devices. Cycling dynamic data can also be analyzed in Garmin Connect by uploading and viewing the details of the activity.
Cycling dynamics include:
Cycling Dynamics Requirements
In order to record cycling dynamics data during your ride, you must meet the following requirements:
  • You own a dual-sensing Rally or Vector 3 power meter pedal set.
    • Rally RK200, RS200, or XC200.
    • Vector 3 (Vector 3S is not a dual-sensing power meter pedal).
  • Your pedals are paired to your head unit or watch via the ANT+ channel.
    • Cycling dynamics data will not transmit via BLE (Bluetooth Low Energy).
    • To check, view Sensors > Power Meter > Connection Type.
    • If you have the option, simply select ANT+ and the channel will switch from BLE to ANT+.
Re-pairing Pedals to the ANT+ Channel
If you need to unpair your pedals in order to pair them via ANT+, select one of the options below to reveal instructions. Otherwise, refer to your owner's manual.
Edge: Button Controlled
  1. Access the menu of the device.
  2. Select Settings.
  3. Select Sensors.
  4. Locate and select your paired Rally or Vector pedals.
  5. Select Remove > Yes.
  6. Select Add Sensor > Search All from Sensors.
  7. Select Power.
  8. Pair the power meter again.
Edge: Touchscreen
  1. Touch Menu Icon.
  2. Select Sensors.
  3. Select the paired Rally or Vector.
  4. Select Remove > Yes.
  5. Select Add Sensor > Search All from Sensors.
  6. Select Power.
  7. Pair the power meter again.
Garmin Watches
  1. Hold UP/MENU to access the main menu.
  2. Scroll to or select Settings.
  3. Select Sensors & Accessories.
  4. Select the paired Rally or Vector.
  6. Select Add New > Search All from Sensors & Accessories to pair the power meter again.
Garmin Devices Compatible With Cycling Dynamics
Choose an option below to reveal a list of devices.
Edge Cycling Computers
  • Edge 520
  • Edge 520 Plus
  • Edge 530
  • Edge 820
  • Edge 830
  • Edge 1000
  • Edge 1030
  • Edge 1030 Plus
Watches
  • D2 Delta series
  • D2 Mach 1
  • Descent Mk2 series
  • Descent G1 series
  • Enduro
  • epix (Gen 2) series
  • fenix 5 series
  • fenix 5 Plus series
  • Forerunner 745
  • Forerunner 935
  • Forerunner 945/945 LTE
  • Forerunner 955/955 Solar
  • Instinct 2 series
  • MARQ Collection
  • fenix 6 series
  • fenix 7 series
  • tactix 7 series
  • tactix Delta series
Garmin Devices Compatible With Power But Not Cycling Dynamics
Choose an option below to reveal a list of devices that will pair and display power data but not cycling dynamics data.
  • Edge 130
  • Edge 130 Plus
  • Edge 500
  • Edge 510
  • Edge 705
  • Edge 800
  • Edge 810
Watches
  • D2 Bravo
  • D2 Charlie
  • D2 Delta series
  • Descent MK1
  • fenix 3 series
  • fenix 5 series
  • fenix Chronos
  • Forerunner 310XT
  • Forerunner 910XT
  • Forerunner 255 Series
  • MARQ Series
  • tactix Bravo
  • Tactix Charlie
  • quatix 3
  • quatix 5
For more information about connecting sensors, see - Best Practices for Connecting Sensors to Your Garmin Device.
