Setting Distance Alerts on the Alpha 10
If you want to set a Distance Alert on your Alpha® 10 dog tracking handheld you can enable it and choose the type of alert by the following:
  1. Press the menu button
  2. Select Setup > Alerts
  3. Scroll down and select Distance
  4. Select the type of alert you want
  5. If you want to change the distance at which the alert is triggered, scroll down and select Distance Threshold
  6. Select the measurement and enter the distance
  7. Select Done
