Setting Up Fuel Settings on a BMW Motorrad Navigator V or VI
The Fuel Settings feature allows you to set up an estimated distance per tank and low fuel warning.
To access the Fuel Settings feature on the BMW Motorrad Navigator V and VI:
- Touch View Map
2. Touch the three menu bars on the bottom right
3. Touch Fuel Settings
4. Enable the Fuel Settings feature
- Select the total estimated distance you can travel on a full tank of gas
- Set the low fuel warning
- An alert will display on the map screen when you have only enough fuel to travel the distance you enter
The example in step 4 is set to travel a total of 200 miles. An alert will display after traveling 150 miles because there are only 50 miles left to drive until empty.
