You are viewing an article that is not available in your currently selected language. You can choose another one below.
Databases That Go Onto The G1000 Supplemental Cards
The Garmin® Supplemental Data cards are stored in the bottom slot of the Primary Function Display (PFD) and the Multi-Function Display (MFD). The following databases are stored on the Garmin Supplemental Data cards:
- Basemap
- Obstacle
- Terrain
- FliteCharts® or Jeppesen Charts - also known as the departure, arrival, and approach plates. Collectively, they are also known as the terminal charts.
- SafeTaxi®
- Airport Directory (AOPA)
When downloading these databases, it is important to note that all of these updates are required to be downloaded to both Garmin Supplemental Data cards, except for the FliteCharts or the Jeppesen Charts databases. The charts database is only required on the MFD Supplemental Data card.
