LiveScope LVS-32 TM or LVS-12 Transom Mount Transducer Forward or Down Orientation Options
LVS-32 and LVS-12 TM transducers can be viewed/used either in “LiveScope Forward” or “Livescope Down”.
There are two ways to orientate the LVS-32 TM or LVS-12 TM transducers to use either “LiveScope Forward” or “LiveScope Down” views.
- Physically re-position the LiveScope transducer to the desired view: "LiveScope Down" or "LiveScope Forward":
LiveScope Down:
- Physically re-position the LiveScope transducer, so the front of the transducer is pointed down and the back is raised approximately 20* up.
- You do not have to adjust LiveScope settings if the orientation is in “AUTO”.
LiveScope Forward:
- Physically re-position the LiveScope transducer, so the top of the transducer is parallel to the surface of the water.
- DO NOT re-position LiveScope transducer (TH or TM), instead adjust LiveScope settings
- Based on the existing orientation of the Livescope transducer, select the associated orientation you want to use: “LiveScope Forward” or “LiveScope Down”. NOT AUTO.
- Turn “AHRS” off.
- Adjust “Pitch” for “LiveScope Forward” view or adjust “Roll” for “LiveScope Down” view.
